ProjeQtOr free project management software - Buttons seem not to work on Planning Screen - ProjeQtOr
10 Mar 2015 20:05 #1 by francis2301
After I've updated to version 4.5.5, there are three buttons in screen "Planning", there are not working. The buttons are "export to MSProject", "Column selection" and "new item - activity, project, milestone". Please see the attached file.
There are no message errors or logs in the log file. It just seems that the button has no behaviour.
I've already clean up the cache (SHIFT + F5), but didn't solved.
Kind regards.
10 Mar 2015 20:43 #2 by babynus
It is issue with message zone, invisible but over buttons.
You may check this by running planning : you'll see not working buttons are hidden by message area.
Quick work around : change zooming or use : hide menu button, the buttons should become active.
I'll look for a fix.
The following user(s) said Thank You: francis2301
11 Mar 2015 13:37 #3 by francis2301
the workarounds worked just fine. thank you
