ProjeQtOr free project management software - Problems with Upgrade to version 4.5.5 - ProjeQtOr
24 Feb 2015 13:55 - 24 Feb 2015 13:56 #1 by francis2301
Hi, how are you doing?
After upgrading to version 4.4.1 to 4.5.5 I'm facing some problems ( :( ), as described below. log file is attached.
- Menu buttons do not appear (not even work when clicked) in screens project, actions, activities, etc (all screens). Please see attached file "menu buttons error".
- Exporting project record to PDF is not working anymore. it seems to happen only on project screen, since other screens are working. Please see attached files "PDF Export error" and also the log file. It says there's an "ERROR n°4 : HTML code invalid, the tags are not closed in an orderly fashion.Status : Array"
- Printing record with problems related to language shown. Application is in PT_BR and labels are shown in French. it seems to happen only on project screen, since other screens are working. Please see attached file "Printing error".
I've checked the online manual. In the section "Install new version", there's a comment about upgrading twice and if there's a problem, double entries in habilitation table should be deleted. I tried to check this table, but couldn't find double entries. Follows attached file with records of habilitation table (attached file "habilitation table.xlsx").
Thanks in advance for any help.
Kind regards.
Last edit: 24 Feb 2015 13:56 by francis2301. Reason: Adding log file in .zip format, instead of .txt
24 Feb 2015 14:16 #2 by francis2301
just an updated. After posting the issue I remembered about pressing Shift + F5. After i did that, the first problem described was solved (- Menu buttons do not appear). However, the other 02 problems still there (PDF and printing project records).
Thanks. Best regards.
24 Feb 2015 22:50 #3 by babynus
Issue is due to deloyment issue.
Directory /report/object should not have been deployed. It contains specific filed for french purpose only.
Please delete this directory and included files.
The following user(s) said Thank You: francis2301
25 Feb 2015 13:37 #4 by francis2301
worked perfectly. thank you
