ProjeQtOr free project management software - State attendue by meeting recording - Page 2 - ProjeQtOr
09 Jan 2015 11:39 #7 by dlalleme
It's ok on demo !
I have an other server with projeqtor 4.3.2 and it works well !
Denis
10 Jan 2015 11:20 #8 by babynus
It seems the migration to V4.5 was not complete.
Check audit table, some columns have changed :
- lastAccessDateTime (V4.5) replacing lastAccess (V4.4)
- connectionDateTime(V4.5) replacing connection(V4.4)
- disconnectionDateTime (V4.5) replacing disconnection (V4.4)
Check assignment table, new column
- notPlannedWork is new column
Check planningelement table, new column
If these changes are not taken into account, the behavior would be exactly what you describe :
- assignment not completely displayed and rest of forml not displayed
- error logged on audit table every 10 second
12 Jan 2015 18:58 #9 by dlalleme
Bonsoir,
The install wasn't issue from migration but from a fresh install!
I check the columns tomorrow
Denis
12 Jan 2015 19:40 #10 by babynus
For information, I never has such issue on fresh installs (and I run some quite often).
On which OS do you Host ProjeQtOr ?
14 Jan 2015 15:29 #11 by dlalleme
Salut,
Here are the tables
-- Table: audit
-- DROP TABLE audit;
CREATE TABLE audit
  id serial NOT NULL,
  sessionid character varying(100),
  auditday character varying(8),
  connectiondatetime timestamp without time zone,
  disconnection timestamp without time zone,
  lastaccess timestamp without time zone,
  duration time without time zone,
  iduser numeric(12,0),
  username character varying(100),
  useragent character varying(400),
  platform character varying(100),
  browser character varying(100),
  browserversion character varying(100),
  requestrefreshparam numeric(1,0) DEFAULT 0,
  requestdisconnection numeric(1,0) DEFAULT 0,
  idle numeric(1,0) DEFAULT 0::numeric,
  requestrefreshproject numeric(1,0) DEFAULT 0::numeric,
  CONSTRAINT audit_pkey PRIMARY KEY (id)
WITH (
  OIDS=FALSE
it-s OK for assignment and planningelement tables
Denis
15 Jan 2015 12:57 #12 by babynus
The description of your audit table is very strange.
In V4.5, 3 columns were renamed :
connection to connectionDateTime
disconnection to disconnectionDateTime
disconnection to lastAccessDateTime
Here is what creation script should look like :
CREATE TABLE IF NOT EXISTS `audit` (
`id` int(12) unsigned NOT NULL,
  `sessionId` varchar(100) DEFAULT NULL,
  `auditDay` varchar(8) DEFAULT NULL,
  `connectionDateTime` datetime DEFAULT NULL,
  `disconnectionDateTime` datetime DEFAULT NULL,
  `lastAccessDateTime` datetime DEFAULT NULL,
  `duration` time DEFAULT NULL,
  `idUser` int(12) unsigned DEFAULT NULL,
  `userName` varchar(100) DEFAULT NULL,
  `userAgent` varchar(400) DEFAULT NULL,
  `platform` varchar(100) DEFAULT NULL,
  `browser` varchar(100) DEFAULT NULL,
  `browserVersion` varchar(100) DEFAULT NULL,
  `requestRefreshParam` int(1) DEFAULT '0',
  `requestDisconnection` int(1) DEFAULT '0',
  `idle` int(1) unsigned DEFAULT '0',
  `requestRefreshProject` int(1) unsigned DEFAULT '0'
) ENGINE=InnoDB AUTO_INCREMENT=9001 DEFAULT CHARSET=utf8;
What is the most weird, is that the renaming of the 3 columns is done in ProjeQtOr with one only query :
ALTER TABLE `${prefix}audit` CHANGE `connection` connectionDateTime datetime,
CHANGE `disconnection` disconnectionDateTime datetime,
CHANGE `lastAccess` lastAccessDateTime datetime;
So I cannot explain that your database is updated on only 1 of the 3 columns. It should be all or none (if error occured).
How did you install ? Really using default scripts ?
On which OS does the issue happen ?
Is you Database MySql or PostgreSql ? Which version ?
