ProjeQtOr free project management software - Strings not translated to Brazilian Portuguese - ProjeQtOr
06 Nov 2014 15:07 #1 by francis2301
I realized that when using projeqtor in Brazilian Portuguese some labels/captions do not shown a translated string, but the label/caption name.
Please take a look at the attached file. I couldn't find the the strings mentioned in attachment into Projeqtor Translation file.
PS: you'll see in the attachment there's a string named "[colExpenseAssignedAmount]". In projeqtor translation file I was searching for "colExpenseAssignedAmount"
Please let me know if there is something I'm doing wrong in the translation file.
Thank you.
Francis.
06 Nov 2014 15:35 #2 by babynus
Yoiur way to work with lang.xls file seems correct.
PROJECT SCREEN : theese captions were missing on V4.4, are added in V4.5
ACTIVITY SCREEN : theese captions were missing on V4.4, are added in V4.5
REAL WORK ALLOCATION SCREEN : this caption already exists on V4.4, should be on line 1070
USER PARAMETER SCREEN : this caption already exists on V4.3, should be on line 1087
Regards.
06 Nov 2014 18:07 - 06 Nov 2014 20:19 #3 by francis2301
Hi babynus,
Thank you. I was using a lang.xls file not up to date.
PS: The translation file available for download in the website are with brazilian portuguese strings incorrect (the values are equal to Portuguese-Portugal, which is incorrect). Attached follows the updated file (already with the corrections in the strings mentioned in your previous answer).
Thanks a lot.
Last edit: 06 Nov 2014 20:19 by francis2301. Reason: Uploading the correct lang.xls file
07 Nov 2014 00:31 #4 by babynus
You new version is taken into account, ready for next deployment of ProjeQtOr. ;)
The following user(s) said Thank You: francis2301
