ProjeQtOr free project management software - Greek language - ProjeQtOr
Greek language
27 Oct 2014 20:50 - 28 Oct 2014 02:35 #1 by 8omas
Greek language was created by 8omas
I began translating to Greek (el)
First of all, thx for the very good work.
Second
One of the problems has to do with the implementation.
in GeneralWork.php
you have :
  public static function displayShortWorkUnit() {
    self::setWorkUnit();
    $res=substr(i18n(self::$workUnit),0,1);
    return $res;
The problem is that the word hours is translated in Greek as 'ώρες'.
The problem is solved if we write the above function as :
    $res=substr(i18n(self::$workUnit),0,2);
    return $res;
Third
I think that the xls file is outdated. After I made some translations and created the lang.js some of the strings in the GUI showed as [xxxxxxxxxx]
Thx again
Last edit: 28 Oct 2014 02:35 by 8omas.
28 Oct 2014 02:34 #2 by 8omas
Replied by 8omas on topic Greek language
The same applies in Calendar.php at line 234
So the code
$result.=  substr(i18n(date('l',$iDay)),0,1) . $d ;
become
$result.=  substr(i18n(date('l',$iDay)),0,2) . $d ;
28 Oct 2014 13:36 #3 by babynus
Replied by babynus on topic Greek language
Your solutions works only woth greek language and would lead to display "da" for days in english.
It is because in greek, the first letter is 2 bytes long in UTF-8.
So, solution is :
    $res=mb_substr(i18n(self::$workUnit),0,1);
    return $res;
Will be fixed this way in V4.5
28 Oct 2014 13:46 #4 by babynus
You were right : lang.xls file was about V4.3.
I updated with V4.4 one.
NB : rather than trying to copy your changes in new fie, I think it will be more easy to sort on Version the V4.4 file, and then copy the last lines into your own competed file (you'll get less chance for errors)
The following user(s) said Thank You: 8omas
28 Oct 2014 14:46 #5 by 8omas
babynus wrote: Hi,
So, solution is :
    return $res;
Even with this change I don' see the correct character.
As I wrote in the other utf8 post I think that the problem has to do with something like this:
mathiasbynens.be/notes/mysql-utf8mb4
28 Oct 2014 22:34 - 28 Oct 2014 22:38 #6 by 8omas
This is the first version. There are some more strings to translate
Last edit: 28 Oct 2014 22:38 by 8omas.
Time to create page: 0.064 seconds
