ProjeQtOr free project management software - Error occurs when allocation real work - ProjeQtOr
14 Oct 2014 15:37 #1 by BasGobets
I've been using Projeqtor for a couple of months now, and I am pretty happy with it.
I have, however, come across a problem in Real work allocation.
When I try to save changes made to the allocated work (1 hour extra) I get an error message "ERROR: An orror occurred on <date> at <time>". Contact your administrator" (see attached screenshot)
Changes made are not saved.
I have observed that the problem does not occur for all resources. I get the impression that it occurs for resources that assigned to many tasks.
I have added
php_value max_input_vars 4000
php_value suhosin.post.max_vars 4000
php_value suhosin.request.max_vars 4000
to php.ini and restarted the server, but this does not solve the problem
Any ideas?
Kind regards,
S.Gobets
14 Oct 2014 16:53 #2 by babynus
Php_value is to be defined in .htaccess file:
But then your apache confifiguration must allow .htaccesss changes :
AllowOverride All
You can also directly change value in PHP.ini, but syntax is a bit different :
max_input_vars = 4000
suhosin.post.max_vars = 4000
suhosin.request.max_vars =4000
The following user(s) said Thank You: BasGobets
27 Oct 2014 19:56 #3 by BasGobets
I must have done something wrong before, because it turned out that these 3 lines were not added after all.
I did add them properly this time, restarted the web services, and now it seems to work properly. Thanks, and sorry for the trouble.
