ProjeQtOr free project management software - Planning Parallel Activities on Same Resource - Page 3 - ProjeQtOr
07 Oct 2014 10:08 #13 by protion
It is clear that the creation of the task requires a minimum of reflection to optimize the use of the software.
But it is good that you are finding a solution to your problem.
Il est clair que la création des tache demande un minimum de réflexion afin d'optimiser l'utilisation du logiciel.
Mais il est bien que tu es trouver une solution à ton problème.
07 Oct 2014 13:47 #14 by babynus
Hi prg,
Happy to read you solved your issue.
Your request about new planning mode "must not be interrupted" may look like a good idea, but would be a mess to implement and, I think, will lead to very frustrating results.
Let's concider a short exemple :
Activity A1 / Priority 1 / Resource R1 : 1 day
Activity A2 / Priority 1 / Resource R2 : 1 day , and predecessor A1
Activity A3 / Priority 2 / Resource R3 : 2 days, no predecessor planning mode "must not be interrupted"
The result would be :
Day 1 : R1 on A1
Day 2 : R2 on A2
Day 3 : R2 on A3
Day 4 : R2 on A3
As A2 is planned as "must not be interrupted", it cannot start on Day 1, as it would be interrupted on Day 2 by A2, with more urgent Priority.
So R2 has no work planned on D1.
So, if result expected is :
Day 1 : R1 on A1, R2 on A3
Day 2 : R2 on A3
Day 3 : R2 on A2
(which is the most optimized planning)
you just have to play with priorities (A1=>P1, A2=>P2, A3=>P1).
07 Oct 2014 13:53 #15 by prg
Eheh, I know.
Unfortunately there are a mess of possible planning criteria (that's why project mgmt is fantastic!!).
Mine was just an idea; let's keep it in the whish list.
07 Oct 2014 13:58 #16 by babynus
Ticket #1543 recorded to keep it in mind
