ProjeQtOr free project management software - JS error in Real Work Allocation - ProjeQtOr
28 Aug 2014 17:23 #1 by 002514
Hi
I meet an Javascript error in the Real Work allocation menu. I can't change resource. I obtain the following error. (just for information i deleted my cache) ;)
TypeError: dojo.byId(...) is null
dojo.byId('hideNotHandled').checked=dojo.byId('listHideNotHandled').checked;
view/js/projeqtorWork.js?version=V4.4.1.0105
formInitialize();
dojo.byId('userId').value=dijit.byId('userName').get("value");
dojo.byId('idle').checked=dojo.byId('listShowIdle').checked;
dojo.byId('showPlannedWork').checked=dojo.byId('listShowPlannedWork').checked;
dojo.byId('hideDone').checked=dojo.byId('listHideDone').checked;
dojo.byId('displayOnlyCurrentWeekMeetings').checked=dojo.byId('listDisplayOnlyCurrentWeekMeetings').checked;
loadContent('../view/refreshImputationList.php', 'workDiv', 'listForm', false);
return true;
Yannick
28 Aug 2014 19:27 #2 by babynus
Several workarounds are possible :
1) In global parameters, on "Real Work allocation" section, set "Display only handeled tasks" to "No"
=> This fixes the issue.
2) Comment line 65 in /view/js/projeqtorWork.js
//dojo.byId('hideNotHandled').checked=dojo.byId('listHideNotHandled').checked;
Thanks for reporting the issue.
Ticket #1509 recorded to fix the issue.
28 Aug 2014 19:53 #3 by babynus
Final fox is replace in /view/js/projeqtorWork.js, line 65
with
if (dojo.byId('hideNotHandled') && dojo.byId('listHideNotHandled') ) {
The following user(s) said Thank You: 002514
