ProjeQtOr free project management software - Connection problem update v3.3.x to v.4.3.3 - ProjeQtOr
29 Jul 2014 15:19 #1 by DanielF
I cant update my install of ProjeQtOr from 3.4.4 to 4.3.3.
When I trying to login for update database Error connection
Connection LDAP KO, connection user admin local KO.
I done many test 3.4.4 to 4.0.0 KO too
Help me please.
29 Jul 2014 15:56 #2 by babynus
Did you refresh your browser cache ?
(there are some important js changes in login phase)
29 Jul 2014 15:59 #3 by DanielF
Yes,
I'm doing again and I have same problem
29 Jul 2014 16:22 #4 by babynus
I'm almost sure it is a cache issue.
I could reproduce :
setup V3.4.4, and install : OK
upgrade ot V4.3.3 => issue while login, with error logged in log file
2014-07-29 16:14:08 ***** ERROR ***** Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'salt' in 'field list'
2014-07-29 16:14:08 ***** ERROR *****    For query : update resource set password='cc0bde50b9b5cadfd0389e00bddf193e301704079c1ceabd2bd79a883e83dfcb' , salt='b62d903c0f924eae9822ca90ec9c1e87d3665da5803dbbca7d3c13ae37c66723' , crypto='sha256' , passwordChangeDate='2014-07-29'  where id=1
2014-07-29 16:14:08 ***** ERROR *****    Strack trace :
2014-07-29 16:14:08 ***** ERROR *****    #0 Sql->query called at [D:\www\projeqtor\model\persistence\SqlElement.php:801]
2014-07-29 16:14:08 ***** ERROR *****    #1 SqlElement->updateSqlElement called at [D:\www\projeqtor\model\persistence\SqlElement.php:476]
2014-07-29 16:14:08 ***** ERROR *****    #2 SqlElement->saveSqlElement called at [D:\www\projeqtor\model\persistence\SqlElement.php:371]
2014-07-29 16:14:08 ***** ERROR *****    #3 SqlElement->save called at [D:\www\projeqtor\model\User.php:663]
2014-07-29 16:14:08 ***** ERROR *****    #4 User->save called at [D:\www\projeqtor\tool\changePassword.php:61]
2014-07-29 16:14:08 ***** ERROR *****    #5 changePassword called at [D:\www\projeqtor\tool\changePassword.php:36]
Then refreshed browser cache : [Shift]+[F5] was enough on my chrome browser.
And connect again : all works fine, upgrade correct.
1) Try to clean browser cache, with [Shift]+[F5]
2) Try to clean browser cache, with parameters options of browser
3) Try to connect with another browser
If none works, have a look at your Apache and PHP cache.
(Zend server manages some cache it is possible to clean throught the Zend GUI)
29 Jul 2014 16:22 #5 by babynus
I could reproduce :
29 Jul 2014 17:07 #6 by DanielF
OK !
I retryed with Internet Explorer 11, clean browser ..... KO
I tryed with Chrome > success first time.
Thanks a lot.
