ProjeQtOr free project management software - Attachments with IE 8 - ProjeQtOr
17 Jun 2014 18:00 #1 by caccia
Attachments with IE 8 was created by caccia
For some reason, on an older version of Internet Explorer (8), it is not possible to attach files.
Works ok on IE 11, but unfortunately some people need to use IE8 on customer site...
Would you have any ideas ?
17 Jun 2014 18:11 #2 by babynus
Replied by babynus on topic Attachments with IE 8
Attachments uses HTML5 capacities when available, and standard when not.
It is defined in js function :
function isHtml5() {
	if (dojo.isIE && dojo.isIE<=9) {
		return false;
	} else if (dojo.isFF && dojo.isFF<4) {
		return false;
	} else {
		return true;
Check that is gives correct result on your environment.
