ProjeQtOr free project management software - Refesh Gantt after calendar modification - ProjeQtOr
11 Jun 2014 10:17 #1 by LU611
I've a problem when I change information in calendars.
Calculations are correct, but there is no change on the representation of working days or not.
It is necessary to disconnect and reconnect to see the changes.
Can you confirm this behavior? A correction is possible?
We are in the analysis phase before deployment and this is a problem for us.
11 Jun 2014 12:07 #2 by babynus
Do you mean that you change working/off days in a calendar and you don't see changes ?
Where do you expect to see these changes ?
=> in planning : only default calendar off days are displlayed
=> agenda : should be correct
=> real work allocation : should be correct
11 Jun 2014 13:54 #3 by LU611
Hy,
absolutly !!!
I change just in default calendar .
So, in planner :
After change, in planning, the new off days isn't display in grey.
After disconnect/reconnect : it's OK.
In Agenda : it's correct immediatly
The real work allocation : it's correct immediatly.
Is it possible that the frame calendar isn't redraw and that just the gantt bar are recalculated ?
11 Jun 2014 16:20 #4 by babynus
No exactly.
It is because Gantt is drawn is Javascript, and using off days table stored in Javascrtipt.
And this list is loaded only on start page...
Ticket #1402 recorded to look for an improvement.
Does not seem to be blocking ;)
The following user(s) said Thank You: LU611
