ProjeQtOr free project management software - No color in "Colored monthly ressource planning" - ProjeQtOr
29 Apr 2014 14:13 - 29 Apr 2014 14:27 #1 by milien56
Hi All,
I'm running V4.2.3 (on RedHat EL6) and i'm facing a display Issue with "Colored monthly ressource planning" Pannel.
Indeed no colors are displayed (tested with chrome Version 34.0.1847.131 and IE.
Enclosed is a screen shot of problem.
Thanks for your support
Last edit: 29 Apr 2014 14:27 by milien56.
29 Apr 2014 15:28 #2 by babynus
First you have to define a color for each project ;)
then you have to check that your browser enables "print images and background colors"
29 Apr 2014 15:31 #3 by milien56
Argh... :blush:
Thanks for prompt answer..so simple ! :whistle:
