ProjeQtOr free project management software - Display problem. - ProjeQtOr
Display problem.
29 Apr 2014 14:03 - 29 Apr 2014 14:04 #1 by lutror
Display problem. was created by lutror
We have recently updated Projeqtor to the version 4. Now we have a display problème. Activities appear not under their activity parent but under the last activity in the list (see file).
Thank you.
Last edit: 29 Apr 2014 14:04 by lutror.
29 Apr 2014 15:34 #2 by babynus
Replied by babynus on topic Display problem.
You're facing an already identified and fixed issue.
www.projeqtor.org/index.php/forum/2-subm...re-ordering-projects
If you are using V4.2.3, just move parent activity or parent project (twice to set it bacj to correct place)
It will fix display issue.
