ProjeQtOr free project management software - SQL Exception on elements updates - Page 2 - ProjeQtOr
14 Apr 2014 17:03 #7 by Iaurkano
Yes but, very strange to need to increase this time out, because the current value 50 seconds seems to be huge for an update or one record.
In my case, this appears when i want to update a status in an activity.
thank's,
14 Apr 2014 17:42 #8 by Iaurkano
last information
i restarted the apache server, and the message does not appear any more.
i'm going to migrate to 4.2.2 version and will check if the issue still present.
So it seems it's not a Database issue.....
see you...
14 Apr 2014 19:06 #9 by babynus
So possibly you has some existing PHP session with not comitted transaction locking some tables.
Possibly you have some configuration that enables to have very long peristent transaction (no timeout ?)
Latest version is 4.2.3 ;)
The following user(s) said Thank You: Iaurkano
15 Apr 2014 15:10 - 15 Apr 2014 15:10 #10 by Iaurkano
After investigation, i found how to generate the problem :
1- i perform multiple updates, for activity status (at least) .
2- an error occurs during multiple update because a status cannot be changed because of the workflow. In the 3.4.4 version, Projectorria does not indicate any errors, the hourglass stay indefinitely, and i must close firefox to exit projectorria. after reconnection I get the MySQL Error, on the record where the error occurs.
This issue does not appear with 4.2.2, so i m going to migrate ASAP.
Hi all.
Last edit: 15 Apr 2014 15:10 by Iaurkano.
