ProjeQtOr free project management software - [SOLVED] Ldap connection user filter on 4.2.2 - ProjeQtOr
01 Apr 2014 15:35 - 01 Apr 2014 16:47 #1 by Iaurkano
Hi, babynus,
i meet an issue on the new freeshly installed 4.2.2 with the ldap connection.
so, in the "globals parameters" screen, the "user filter" field contains on my old version (3.4.4) this : samaccountname=%USERNAME%
on the the new it seems the value is not read, the value displayed is : uid=%USERNAME%
if i change the value projeqtor indicate "no change made nothing save". so i can't modify these value, and the ldap connection does not work anymore..
thank's for all.
regards.
Last edit: 01 Apr 2014 16:47 by Iaurkano.
01 Apr 2014 15:59 #2 by babynus
It seems you defined this parameter also in your parameters.php file.
Remove it from there should fix your issue.
01 Apr 2014 16:09 #3 by Iaurkano
is it possible to delete the parameter.php file ????
01 Apr 2014 16:33 #4 by babynus
NO,
it contains information about DataBase connection ...
01 Apr 2014 16:35 #5 by Iaurkano
so i just need to keep database connection info.
all other informations like ldap connection can be deleted safely ? right ?
thank's for all Babynus.
01 Apr 2014 16:39 - 01 Apr 2014 16:39 #6 by babynus
Must also keep log filename.
(as it is needed even before database connection, and to report connection errors)
That's all.
Last edit: 01 Apr 2014 16:39 by babynus.
