ProjeQtOr free project management software - Installation Issue on CENTOS 6.4. - ProjeQtOr
23 Mar 2014 05:39 #1 by deepakchougule
Hi Though a similar issue is filed earlier , this issue seems to be related to the same thing.
Getting an error message while installation :-
incorrect value for 'Log file name', cannot write to such a file
Tried all the tricks and tips mentioned , web server folder access and file access permission but it still it is not working.
23 Mar 2014 13:35 #2 by babynus
First, directroy "/var/www/html/PROG/logs must exist.
Then try a "chmod 777 /var/www/html/PROG/logs" (do this as root to be sure). This should fiw the issue.
Be aware that user running PHP may be different from current user.
If my memory is correct PHP user is "apache" on centos/redhat, and "www-data"' on "ubuntu/debian".
24 Mar 2014 02:16 - 24 Mar 2014 02:18 #3 by deepakchougule
Dear Colleague,
I tried this again changed the permission for logs folder to 777 as a root user i.e. "chmod 777 /var/www/html/PROJ/logs" still the problem persists.I have added screen shots for your reference.
Best Regards,
Deepak Chougule.
Last edit: 24 Mar 2014 02:18 by deepakchougule. Reason: Screenhots not added.
24 Mar 2014 09:39 #4 by babynus
Is there an already existing file logs.log in logs directory ?
