ProjeQtOr free project management software - Odd project/subproject/activity positioning - ProjeQtOr
18 Mar 2014 00:07 #1 by alcassanti
After creating some projects with subprojects and some activities, In the planning function I started to change the position to fit the real order I want projects to be planned.
I had 1 master project (my program) with 3 projects under it (there's more to add but I got stuck at this point and it's enough to explain the issue). and some activities planned under some projects.
As I moved project 1.3 above project 1.2 (intentionally to change the wbs) it changed the wbs of projects and activities correctly but this resulted in a very odd positioning, as shown on the attachment.
18 Mar 2014 11:06 #2 by babynus
I guess you're in V4.1 or previous version.
This is an issue fixed in V4.2
18 Mar 2014 15:39 #3 by alcassanti
You're right... I'm still using v4.1.2.
I will run the update and see what happens (and give you some feedback).
Thanks :D
19 Mar 2014 19:22 #4 by alcassanti
Problem solved updating to v4.2.1
Thanks!
