ProjeQtOr free project management software - Move project or activity in the planning - ProjeQtOr
06 Mar 2014 14:49 - 06 Mar 2014 14:50 #1 by Drubs2010
I have à problem with moving activity or project in the planning.
When I use Drag and Drop to move an activity which contains activities and/or milestones, only the main line move not all the lines (See exemple attached).
Is there a method to avoid this problem?
Drubs2010.
Last edit: 06 Mar 2014 14:50 by Drubs2010.
06 Mar 2014 15:00 #2 by babynus
Strange, it is working fine (as you expect) on my side. :blink:
Which task did you move, from where to where ?
Which version of ProjeQtOr ?
06 Mar 2014 16:21 - 06 Mar 2014 16:33 #3 by Drubs2010
I move Production, but LED, MEP and PV de livraison stay at the same place. It's version 4.1.2.
If I want to return to normal operations, I have to go in every line and save them one by one.
Last edit: 06 Mar 2014 16:33 by Drubs2010. Reason: More Informations
07 Mar 2014 09:42 #4 by babynus
You're facing WBS renumbering issue.
You can display WBS in Gantt to ckeck this.
This issue is fixed on V4.2.0 : ticket #1301
07 Mar 2014 14:51 #5 by Drubs2010
Ok, I see it.
I update to 4.2.0 and it's run.
Drubs2010.
10 Mar 2014 17:01 #6 by jphuart
I have the same problem and a lot of blocks has been moved so it's a mess. Fortunately WBS numbering seems correct, just that when I expand a project, its activities show up in weird places into the planning.
My question is, do I have to save each activity one by one to see it again under it's project, or upgrading to version 4.2.0 will do the trick automatically?
Thanks a lot
Jean Pierre
