ProjeQtOr free project management software - Instal issues - ProjeQtOr
Instal issues
03 Mar 2014 22:30 #1 by smonnot
Instal issues was created by smonnot
I just installed this great solution on a test infrastructure.
The installation was successful.
However, I can not create anything.
When I go into the project and I click on create new project I only return the following:
id: ERROR: An error occurred on 2014-03-03 at 10:20:41 p.m.
when I open the log file, I have the following message;
2014-03-03 10:20:41 p.m. ***** ERROR ***** ERROR *****
2014-03-03 10:20:41 p.m. ***** ERROR ***** on file 'E: \ www \ projet_aud \ model \ persistence \ SqlElement.php' at line (3206)
2014-03-03 10:20:41 p.m. ***** ERROR ***** because = Undefined index: REQUEST_URI
Could you help me?
Thank you in advance.
03 Mar 2014 22:57 - 03 Mar 2014 23:00 #2 by babynus
Replied by babynus on topic Instal issues
It seems it is an issue that happen with IIS server.
You can try the following fix.
Update file /model/persistence/SqlElement.php, line 3199 from :
public function getReferenceUrl() {
    $url=(((isset($_SERVER['HTTPS']) and strtolower($_SERVER['HTTPS'])=='on') or $_SERVER['SERVER_PORT']=='443')?'https://':'http://')
    .$_SERVER['SERVER_NAME']
    .(($_SERVER['SERVER_PORT']!='80' and $_SERVER['SERVER_PORT']!='443')?':'.$_SERVER['SERVER_PORT']:'')
    .$_SERVER['REQUEST_URI'];
to
    if (!isset($_SERVER['REQUEST_URI'])) {
      $_SERVER['REQUEST_URI'] = substr($_SERVER['PHP_SELF'],1 );
      if (isset($_SERVER['QUERY_STRING'])) { $_SERVER['REQUEST_URI'].='?'.$_SERVER['QUERY_STRING']; }
If it works, it will be deployed in fixing patch.
Last edit: 03 Mar 2014 23:00 by babynus.
The following user(s) said Thank You: smonnot
