ProjeQtOr free project management software - Issue exporting PDF opportunities - HTML error - ProjeQtOr
19 Feb 2014 17:15 #1 by Rexeh
When running the PDF export on opportunities on V4.0.6
2014-02-19 15:58:45 ***** ERROR ***** on file '/var/www/html/oria/external/html2pdf/_class/parsingHtml.class.php' at line (119)
2014-02-19 15:58:45 ***** ERROR ***** cause = ERROR n°4 : HTML code invalid, the tags are not closed in an orderly fashion.Status : Array
[0] => page
[1] => table
HTML : ...style="width:15%;"></td></tr></page>...
2014-02-19 15:58:45 ***** ERROR ***** => #0 /var/www/html/oria/external/html2pdf/html2pdf.class.php (407) -> parse()
2014-02-19 15:58:45 ***** ERROR ***** => #1 /var/www/html/oria/view/print.php (159) -> writeHTML()
2014-02-19 15:58:45 ***** ERROR ***** => #2 /var/www/html/oria/view/print.php (143) -> finalizePrint()
[ec2-user@ip-172-31-46-13 logs]$ tail projector_20140219.log
2014-02-19 16:07:37 ***** ERROR ***** on file '/var/www/html/oria/external/html2pdf/_class/parsingHtml.class.php' at line (119)
2014-02-19 16:07:37 ***** ERROR ***** cause = ERROR n°4 : HTML code invalid, the tags are not closed in an orderly fashion.Status : Array
[0] => page
[1] => table
2014-02-19 16:07:37 ***** ERROR ***** => #0 /var/www/html/oria/external/html2pdf/html2pdf.class.php (407) -> parse()
2014-02-19 16:07:37 ***** ERROR ***** => #1 /var/www/html/oria/view/print.php (159) -> writeHTML()
2014-02-19 16:07:37 ***** ERROR ***** => #2 /var/www/html/oria/view/print.php (143) -> finalizePrint()
19 Feb 2014 23:26 #2 by babynus
I could not reproduce this issue.
See attached file...
Do you have somethng special in your opporunity description ? Something that could look like an html tag ?
Could you provide a print screen of the oppotunity ?
20 Feb 2014 19:07 #3 by Rexeh
Can't post content as it's sensitive, however I can tell you we have:
- A HTML link as external source (includes = char)
- Description contains & and ( ) chars
There are notes present, as well as pictures on some of them. The notes contain no additional characters that the description does, so must be one of these.
20 Feb 2014 21:08 #4 by babynus
Could not reproduce even with your information...
See attached result of test.
Could you try and reproduce on the Demo ?
21 Feb 2014 15:34 #5 by Rexeh
Think I know why we can't reproduce here!
I'm talking about the Report (Current Status > Opportunity Plan > Export to PDF). If you pop on skype I could send that over if you still can't reproduce!
Rob
21 Feb 2014 15:51 - 21 Feb 2014 15:51 #6 by babynus
This report is not part of the Community Version. :woohoo:
I guess you designed it on your own... ;)
... and maybe that's why pdf export fails. :evil:
... and sure that's why I cannot reproduce B)
Last edit: 21 Feb 2014 15:51 by babynus.
