ProjeQtOr free project management software - SQL error in log when connecting - ProjeQtOr
11 Feb 2014 11:03 - 11 Feb 2014 11:05 #1 by lfrugere
On a new install (new MySQL database, new installation directory, version 4.1.2 on Unix OS) we have an error in log when connnecting to ProjeQtOr.
2014-02-11 10:44:41 ===== TRACE ===== NEW CONNECTED USER 'xxxxx'
2014-02-11 10:44:43 ***** ERROR ***** Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'TestSession.id' in 'where clause'
2014-02-11 10:44:43 ***** ERROR ***** For query : select * from testsession where (exists (select 'x' from assignment x where x.refType='TestSession'
and x.refId=TestSession.id and x.idResource='5')) and idle=0 and done=0 LIMIT 101
2014-02-11 10:44:43 ***** ERROR ***** Strack trace :
2014-02-11 10:44:43 ***** ERROR ***** #0 Sql->query called at [/var/www/projeqtor/model/persistence/SqlElement.php:1285]
2014-02-11 10:44:43 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/projeqtor/view/today.php:418]
2014-02-11 10:44:43 ***** ERROR ***** #2 showActivitiesList called at [/var/www/projeqtor/view/today.php:342]
2014-02-11 10:44:43 ***** ERROR ***** #3 showAssignedTasks called at [/var/www/projeqtor/view/today.php:597]
2014-02-11 10:44:43 ***** ERROR ***** Exception-[42S22] SQLSTATE[42S22]: Column not found: 1054 Unknown column 'Meeting.id' in 'where clause'
2014-02-11 10:44:43 ***** ERROR ***** For query : select * from meeting where (exists (select 'x' from assignment x where x.refType='Meeting' and x.re
fId=Meeting.id and x.idResource='5')) and idle=0 and done=0 LIMIT 101
2014-02-11 10:44:43 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/projeqtor/view/today.php:421]
We have disabled every authorization to "Tests" module.
Problem seems to be case sensitive (TestSession.id instead of testsession.id).
With a MySQL client :
mysql> select * from testsession where (exists (select 'x' from assignment x where x.refType='TestSession' and x.refId=TestSession.id and x.idResource='5')) and idle=0 and done=0 LIMIT 101;
ERROR 1054 (42S22): Unknown column 'TestSession.id' in 'where clause'
mysql> select * from testsession where (exists (select 'x' from assignment x where x.refType='TestSession' and x.refId=testsession.id and x.idResource='5')) and idle=0 and done=0 LIMIT 101;
Empty set (0.01 sec)
Lionel
Last edit: 11 Feb 2014 11:05 by lfrugere.
11 Feb 2014 14:39 - 11 Feb 2014 14:39 #2 by babynus
MySql table names are not case sensitive on Windows, but are on Linux.
You can change this using specific configuration paramter, such as
/my.ini: lower_case_table_names=1
Another workaroung is to disable "Assigned tasks" in Today view.
Last (but not least), you can try patch attached : today.php should be copied in /view folder (replacing existing one, after unzipping)
Last edit: 11 Feb 2014 14:39 by babynus.
14 Feb 2014 18:11 #3 by lfrugere
Thanks,
That works !
