ProjeQtOr free project management software - closed projects re-opening - ProjeQtOr
17 Jan 2014 16:42 #1 by gengen
I tried to re-open some closed projects and it failed if resources were affected to those projects (if no resource are affected, re-opening is possible).
But I can re-open the activities depending on these projects. So imputation are possible (even if the parent project is still closed).
Here is the error I get when the re-opening fails :
2014-01-17 16:00:08 ***** ERROR ***** ERROR *****
2014-01-17 16:00:08 ***** ERROR ***** on file '/appli/projeqtor-v4.1.1/model/User.php' at line (550)
2014-01-17 16:00:08 ***** ERROR ***** cause = Undefined property: Affectation::$idUSer
Is there something more to do or to check before re-opening a project ?
17 Jan 2014 19:52 - 17 Jan 2014 19:52 #2 by babynus
Replied by babynus on topic closed projects re-opening
To fix this issue, replace in file /model/User.php, line 550
$auditList=$audit->getSqlElementsFromCriteria(array("idUser"=>$aff->idUSer, 'idle'=>'0'));
with
$auditList=$audit->getSqlElementsFromCriteria(array("idUser"=>$aff->idUser, 'idle'=>'0'));
Fix will soon be deployed in new patch version.
Last edit: 17 Jan 2014 19:52 by babynus.
20 Jan 2014 11:05 #3 by gengen
Replied by gengen on topic closed projects re-opening
I had to read your message 5 times to see the difference :lol:
I installed ProjeQtOr 4.1.2 this morning and it fixed the issue.
Thanks again for your very quick support :)
