ProjeQtOr free project management software - Project filter and Version menu - ProjeQtOr
15 Jan 2014 21:05 #1 by 002514
Hi
After to have selected a specific projet in the project list (filter), i open version menu, i see all version of all projects. Normally, i should see only the version of the project selected in the filter .
Is it correct ? :huh:
Thank you
Yannick
15 Jan 2014 23:32 #2 by babynus
No,
Environmental parameters items, are not project dependant, even if you can define link with project.
For version, link to project will only have effect on content of version dropbox list.
The following user(s) said Thank You: 002514
