ProjeQtOr free project management software - 4.1.1 installation problem. - Page 2 - ProjeQtOr
12 Jan 2014 16:01 #7 by mabartoletti
the virtualhost hosting projeqtor has currently another simple php app that, however, it is not used (it is a test server).
12 Jan 2014 17:52 #8 by babynus
Replied by babynus on topic 4.1.1 installation problem.
Could you just try with no other application ?
23 Jan 2014 10:44 #9 by mabartoletti
sorry for late reply but i was really busy ...
i try to install it on the main server (where i have no other applicaiton installed), still the same problem. any idea ?
thanks
23 Jan 2014 11:37 #10 by babynus
You could try to force class loading for User : in /tool/projeqtor.php, add line before session_start() so that first lines look like :
<?php
spl_autoload_register('projeqtorAutoload', true);
include_once('../model/User.php');
session_start();              // Setup session. Must be first command.
24 Jan 2014 15:12 #11 by mabartoletti
at the end also this did not work.
then i set-up a virtual machine from scratch and install projeqtor ... it works at first try !!! i do not know whats happen on the original system but now is working.
thanks a lot for your help.
