ProjeQtOr free project management software - Manual - File does not exist - ProjeQtOr
18 Dec 2013 12:16 #1 by evoc
Hi
this is a very interesting project Manager!
I have installed on my server and I move my first steps in knwoledge.
When I try to click the icon of help the windows opened but with a 404 error
The apache log say me this
[Wed Dec 18 11:38:38 2013] [error] [client xx.xx.xx.xx] File does not exist: /usr/share/doc/apache2-doc/manual/manual.php, referer: http://mysite/view/main.php
I have the manual in the original position http://mysite/manual
Have I to move the manual in the apache-doc or there is a configuration item to modify?
Thank You
19 Dec 2013 16:36 #2 by babynus
Manual is search relatively to current position, at ../manual/manual.php
As referer is http://mysite/view/main.php, manual is expected at http://mysite/manual/manual.php.
You can test the behavior on Demo : demo.projeqtor.org (guest/guest)
Here is an example of the structure you should have :
You possibly have an issue in you apache or php configuration or access rights on directories.
19 Dec 2013 17:35 #3 by evoc
Replied by evoc on topic Manual - File does not exist
ok
you are right1
In my apache configuration I have under domain.tld/manual the pager of Apache HTTP Server Version 2.2 Documentation that is under the folder /usr/share/doc/apache2-doc/manual/
This Directive is in the /etc/apache2/conf.d/apache2-doc
Alias /manual /usr/share/doc/apache2-doc/manual/
<Directory "/usr/share/doc/apache2-doc/manual/">
Options Indexes FollowSymlinks
AllowOverride None
Order allow,deny
Allow from all
AddDefaultCharset off
</Directory>
I have changed this configuration in
Alias /apache-manual
Now is ok
Thank you
