ProjeQtOr free project management software - Sent mail doenst work with gmail port 465 - ProjeQtOr
24 Nov 2013 12:00 #1 by ndusch
as explained on the forum the following configuration for sending mails doenst work :
smtp server : ssl://smtp.gmail.com
port 465
user : This email address is being protected from spambots. You need JavaScript enabled to view it.
PW :xx
we use Lotus notes and with IP address and port 25, mails can be sent be only to internal adresses of network.
I use this configuration for sending with vbscript mails (so I know this works well with our network configuration)
Did I miss something?
24 Nov 2013 13:12 #2 by babynus
I just tested with similar configuration : it works fine.
You should check in the log file : you should find detailed error message.
Report it here it is nit explicit enought to help you solve your issue.
Regards.
24 Nov 2013 20:20 #3 by ndusch
Hello babynus
see the log file attached.
regards
ND
24 Nov 2013 23:30 - 24 Nov 2013 23:31 #4 by babynus
No attached file.
Sorry.
Not all formats allowed.
Try and zip it.
Last edit: 24 Nov 2013 23:31 by babynus.
27 Nov 2013 17:18 #5 by ndusch
attached a zip file
File Attachment:
File Name: projeqtor_...1127.zip
File Size:0 KB
27 Nov 2013 18:25 #6 by babynus
Message is clear : you did not eanble ssl in your php configuration :evil:
So connection to gmail in ssl is not possible :whistle:
