ProjeQtOr free project management software - Version 4.0.0 : installation problem. First connection with admin / admin does not work. - ProjeQtOr
04 Nov 2013 13:40 #1 by ambroise1er
Hi Babynus,
Message displayed:
Incorrect logon parameters.
Consequently, the application does not install ...
My environment:
Windows 7
Xampp 1.8.1
04 Nov 2013 15:22 #2 by climb4fun
Hi ambroise1er,
did you copy files in the old 3.4.4 directory or a new directory? I put in the old directory and could work with my old credentials.
Klaus
04 Nov 2013 15:59 - 04 Nov 2013 16:39 #3 by ambroise1er
This is not an update, it is a new installation, in a new directory.
I tryed with différentes versions de XAMPP :
- Version 1.8.1
- Version 1.8.2
- Version 1.8.3
Last edit: 04 Nov 2013 16:39 by ambroise1er.
04 Nov 2013 17:09 #4 by Drubs2010
I have the same problem for a new installation.
Windows XP
XAMP 1.8.2
Drubs2010.
05 Nov 2013 17:22 #5 by climb4fun
Hi ambroise1er and Drubs2010,
I didn't have a solution on the quick run. Two suggestions:
1. check in database, table resource, whether there's a user named admin. If yes, you can copy a encrypted password of your known user in this record. Just copy it from your existing database to the new database. write access is mandatory
2. restore a dump of your already existing Projectorria database. This works in my test deployment.
I hope this is a workaround that helps you.
Klaus
05 Nov 2013 18:09 - 05 Nov 2013 19:03 #6 by ambroise1er
Hi babynus,
This is a critical bug because anyone wishing to install for the first time the version 4.0.0 could not do it ...
:ohmy:
(On Xampp and perhaps on other environnement)
Cordialy
Last edit: 05 Nov 2013 19:03 by ambroise1er.
