ProjeQtOr free project management software - Problem with planning view with Internet Explorer 10 - ProjeQtOr
02 Nov 2013 12:50 #1 by Tomea
Bonjour,
(et merci pour ce trés bon logiciel de gestion de projet)
Dans la vue "planning" le bouton permettant d'afficher/masquer/déplacer certaine colonne ne fonctionne pas sous IE10. Lorsque, par exemple, j'essaie de déplacer (ou de décocher) une colonne par drap and drop Project Or charge indéfiniment.
Cela fonctionne trés bien sous firefox et d'ailleurs les modifications faites sous celui ci sont bien répercutée lorsque je retourne sous IE
(and thank you for this very good software project management)
In the "Plannig view", the button to show / hide / move column does not work in IE10. When, for example, I try to move (or uncheck) a column by drap and drop, Project'Or load indefinitely.
This works very well in firefox and also the changes made in one are reflected well when I return in IE
Thomas.
02 Nov 2013 13:17 #2 by babynus
I confirm this issue with IE10 on V3.4.4. :(
Luckily, it is already fixed in next version, that is coming very soon :woohoo:
14 Nov 2013 17:53 #3 by Tomea
We updated (V4.0.2 (86)) (thanks !)
Unfortunately the problem persists:
In the "follow view" / "Planning": for the vertical scroll bar only affects the right side (not the one with the name of the project)
Similarly, the selection of columns does not work.
this works perfectly in firefox.
Thomas.
15 Nov 2013 13:04 - 15 Nov 2013 13:04 #4 by babynus
Strange.
It works fine for me on IE10 / Windows 7.
First, be sure to clean browser cache and try again.
Then, if you still reproduce the issue, you should have some javascript error in browser console.
Please report it here.
Last edit: 15 Nov 2013 13:04 by babynus.
09 Dec 2013 15:36 #5 by Tomea
Doesn't work...
I found this :
SCRIPT438: L’objet ne gère pas la propriété ou la méthode « preventDefault »
main.php, Ligne 1 Caractère 1
SCRIPT438: L’objet ne gère pas la propriété ou la méthode « indexOf »
projeqtorDialog.js, Ligne 3845 Caractère 4
Thomas.
09 Dec 2013 20:21 #6 by babynus
Ticket #1248 recorded.
