ProjeQtOr free project management software - Setting for "change history" are not propagated - ProjeQtOr
11 Sep 2013 15:14 - 11 Sep 2013 16:01 #1 by sam
In the view "Access to reports", I selected change history visible for profiles: administrative, project leader and manager, but only the user "admin" has visibility. Even another user with administrative rights cannot see the change history.
Last edit: 11 Sep 2013 16:01 by sam. Reason: unvoluntarily copied a question already posted and saved it as ticket
11 Sep 2013 16:15 #2 by babynus
Users must disconnect / reconnect to retrieve new rights.
Did they do so ?
If yes, please provide some print screens.
11 Sep 2013 16:58 #3 by sam
It is not somethg I changed, so yes, users have been re-connecting several times.
here are 2 screen shots.
thx!
11 Sep 2013 22:23 #4 by babynus
Parameters seem correct.
Are you sure users who don't see the expected reports have profile "Manager" or "Project leader"
03 Oct 2013 16:56 #5 by sam
yes they have.
03 Oct 2013 17:31 #6 by babynus
Reviewing your screenshots, there is something I don't understand : you set rights for some report.
You then print screen for item detail.
There is no link.
The rights you set just gives right access to the report...
If you're dealing with seeing history detail on each item, it is a parameter each user must manage himself through "User parameters" screen.
