ProjeQtOr free project management software - Re-opening activities impossible if real work 0 - ProjeQtOr
Re-opening activities impossible if real work <> 0
03 Sep 2013 14:53 #1 by caccia
Hi all,
Doing some migration tests on V3.4.4, I noticed this issue on the workflow controls:
- Activity_1 is in_progress, and real work is logged on it. -> OK
- Activity_1 gets moved to status done. -> OK
- For whatever reason, Activity_1 should be re-opened: this fails, resulting in an error:
"Invalid controls.
the workflow does not allow you to move this item to this status"
From what I've seen, this is only a problem on activities where real work <> 0.
I haven't yet looked into it, but I'll try :)
(Note: I think this may actually be present in V3.4 already, not linked to the latest changes as far as I can tell)
03 Sep 2013 16:25 #2 by babynus
You should check your workflow definition.
I just tried and faced no issue to "re-open" an activity with some real work.
03 Sep 2013 18:42 #3 by caccia
Ohhhh...
Guess it's something wrong on my side then!! :oops:
Thanks anyway!
