ProjeQtOr free project management software - Audit not working - ProjeQtOr
Audit not working
21 Aug 2013 11:45 #1 by mamath
Audit not working was created by mamath
Hello guys,
First, thank you for your work, ProjectOR RIA is exactly what i'm looking for.
My issue :
since you have add access right management in the "control" function of the class SqlElement, no audit are record any more.
Have you already identify this issue ?
I have solve it (temporatly) by changing the line 2256 of the class :
if (get_class($this)=='Alert' or get_class($this)=='Mail' [b]or get_class($this)=='Audit')[/b] {
(in blod my change).
do you confirm the issue ? and plan you too solve it ?
Thank's
Best regards
22 Aug 2013 00:40 #2 by babynus
Replied by babynus on topic Audit not working
You are right.
I did not notice this regression but it is here.
Your fixing is correct !
It will be included in next version.
22 Aug 2013 00:45 #3 by mamath
Replied by mamath on topic Audit not working
ok nice.
16 Sep 2013 16:41 #4 by caccia
Replied by caccia on topic Audit not working
Hi guys,
I just noticed a secondary issue on the Audits:
I used Mamath's fix to get the "audit connections" function working again (thanks!!), but I notice that the report Miscellaneous > Connections Audit is always empty.
Do you also have this issue ?
16 Sep 2013 17:22 - 16 Sep 2013 17:23 #5 by mamath
Yes, i have...
the problem become because they is no record in auditSummary table !!
Last edit: 16 Sep 2013 17:23 by mamath.
16 Sep 2013 17:41 #6 by caccia
Oh, of course... I hadn't realized that AuditSummary was a separate class...
Updating that same line in SqlElement to
if (get_class($this)=='Alert' or get_class($this)=='Mail' or get_class($this)=='Audit'
                or get_class($this)=='AuditSummary')
seems to do the trick.
