ProjeQtOr free project management software - Global parameters seems doesn't take effect on changing - ProjeQtOr
14 Aug 2013 12:00 #1 by jotrong
I change the following but it doesn't take effect:
Currency: EUR to M --> still take EUR sign (default value)
Change icon size: still keep default value
==> So I don't know if it's a bug?
14 Aug 2013 16:20 #2 by LEVA
For the icon issue, I think you have to refresh your cache.
Perhaps for the currency too :)
14 Aug 2013 20:09 #3 by babynus
First you have to save the parameters.
Then disconnect / reconnect : it should reflect your changes.
15 Aug 2013 07:01 #4 by jotrong
I did try it several times, even open new browser to log in. But it still keep same value as default.
15 Aug 2013 15:20 #5 by babynus
1) Save the parameters screen.
2) Check in the table "parameters" the value of parameterValue for parameterCode='currency'
If it is not the value you save : check for errors in the log file.
If it is the correct value : disconect / reconnect.
29 Aug 2013 12:15 #6 by jotrong
Hi Babynus,
I delete all and reinstall and all works fine now.
Thank you for your support
