ProjeQtOr free project management software - project weight - ProjeQtOr
project weight
07 Aug 2013 21:01 #1 by gregius
project weight was created by gregius
hi,
is it possible to classify projects? alphanumerically ?
i can't access wbs
07 Aug 2013 21:49 #2 by babynus
Replied by babynus on topic project weight
Classify ? you mean order ?
Change the WBS !!!
You cannot acces WBS field directly, but you can reorder projects in the gantt planning view (drag & drop with the handler on left of line)
07 Aug 2013 23:10 - 07 Aug 2013 23:45 #3 by gregius
Replied by gregius on topic project weight
k thanks it helps but he doesn't show all my projects...
there is one administrative project that doesn't show up... and when i wanna change it to an internal project... it bugs..
Last edit: 07 Aug 2013 23:45 by gregius.
08 Aug 2013 00:17 #4 by babynus
Since V3.3, the limitation of number of project to display can be increased : change max number in global parameters screen.
You can also reorder projects in Project Portfolio view.
08 Aug 2013 10:08 #5 by gregius
Thanks a lot. it worked.
For a more instinctive solution, it would be nice to have this possibility in the project view... drag and drop or change WBS.
Again, thanks
08 Aug 2013 17:31 #6 by babynus
Difficult to implement here for several reasons :
- liste does not provide drag and drop
- liste can be sorted on other field than WBS
But I will think about it.
