ProjeQtOr free project management software - Invalid controls - ProjeQtOr
Invalid controls
07 Aug 2013 10:33 #1 by ekolossov
Invalid controls was created by ekolossov
In many areas now (from version 3.4, I believe)is not possible to change the type (project, ticket, etc.) even by administrator. Invalid control message (see attachment) popping up.
07 Aug 2013 11:55 #2 by caccia
Replied by caccia on topic Invalid controls
Impressive timing, same as my previous question! ;)
Thanks for pointing out indeed, this seems to be coming from new code of the V3.4.
I notice, concerning the 2 points I mentioned in my earlier post, that by commenting the new "control workflow" code in SqlElement (this part below) I am able to perform the changes to project type and activity status.
Warning: Spoiler!
Of course, I guess this was added for a reason, so commenting out may not be the best way to go... It seems to work as a temporary measure however.
07 Aug 2013 21:47 #3 by babynus
Replied by babynus on topic Invalid controls
Ticket #1159 is recorded : changing type may be unexpectedly refused.
Fix will soon be proposed/
Please notice that you can change type if you change status in the save time (may be a workaround)
The controls you noticed have been added on V3.4 to reinforce workflow control.
Before V3.4, workflow was forced only by proposing limited list of status, corresponding to workflow.
Now, the workflow is also controlled on server side.
This will avoid unexpected change from non trivial media :
- from import
- from multiple change screen (new feature in V3.4)
Control on the status seems correct, but control on type seems incorrect.
09 Aug 2013 12:00 #4 by babynus
This issue is now fixed on V3.4.3 ;)
Please notice that the control still exists and may be blocking, but only when expected.
For instance, imagine you have TypeA where workflow (for current user) is A=>B=>C, and TypeB where workflow is A=>C
If you have element of TypeA in status B, you cannot move it to TypeB without changing status.
09 Aug 2013 12:03 #5 by ekolossov
Replied by ekolossov on topic Invalid controls
Thank you very much!
Hopefully no serious bugs implemented together with fix :)
Evgueni
