ProjeQtOr free project management software - Problem with reply to automatic email sent module - Page 2 - ProjeQtOr
30 Jul 2013 17:30 - 30 Jul 2013 17:32 #7 by lowengrin
In OSX Snow Leopard imap extension not compiled by default in PHP ... ARGHHHH!!! :evil:
I look to support imap without recompiled PHP ...
Thanks babynus
PS: But is a bug when all cron jobs stop when imap extension not enabled ;)
Last edit: 30 Jul 2013 17:32 by lowengrin.
30 Jul 2013 18:36 #8 by babynus
You're right.
this will be fixed in V3.5, to display an error message, and continue Cron execution.
31 Jul 2013 18:41 - 31 Jul 2013 18:46 #9 by abelinux
babynus wrote: Got it :woohoo:
The imap extension is not enabled on your PHP config.
Hi Babynus. Thanks for a great release! including this long expected feature...
I'm having the same problem with IMAP: I configured it (in Global parameters) as explained in the user manual, but can't get it working.
I've deployed v3.4.1 (testing) on a brand new Debian Wheezy (v7), with default Apache server, PHP and MySQL.
- Could you shed some light on how to check this IMAP extension availability? How can I know whether it's enabled or not?
- If not, how can I enable it? ;)
Thanks!
P.S.: I couldn't make it work within the "Live Demo" instance either. Is it disabled there? Or is it that I just don't know how to use this new feature? :S
Last edit: 31 Jul 2013 18:46 by abelinux.
31 Jul 2013 19:23 #10 by babynus
Open your php.ini file, and seach for :
extension=php_imap.dll
on windows
extension=php_imap.so
on linux
It should not be commented.
You can also dowload attached info.php file and run it (after unzipping).
Notice that if you use some ssl interface, open_ssl extension should also be available.
This feature is not available on the Demo (not configured)
The following user(s) said Thank You: abelinux
31 Jul 2013 19:41 #11 by abelinux
Thanks! (swift as usual ;) ) I'll give it a try and let you know whether I succed.
01 Aug 2013 23:33 - 01 Aug 2013 23:35 #12 by lowengrin
Some news ...
I just compile the imap module and all work perfectly ... magic ;)
Thanks for this new feature
Last edit: 01 Aug 2013 23:35 by lowengrin.
