ProjeQtOr free project management software - 3.4.0 - Real work allocation (Timers started post upgrade) - ProjeQtOr
22 Jul 2013 17:03 #1 by Rexeh
Looks like any timers started post upgrade are causing real work allocation page to fail to load.
2013-07-22 15:56:10 ***** ERROR ***** ERROR *****
2013-07-22 15:56:10 ***** ERROR ***** on file '/var/www/vhosts/oria/oria/model/ImputationLine.php' at line (152)
2013-07-22 15:56:10 ***** ERROR ***** cause = Undefined property: Activity::$WorkElement
Tested against 2 x users using timers today, both page loads fail with an error has occured (log above)
Switch USER to a user who hasn't done timers today, and I can see their current week + previous weeks fine.
22 Jul 2013 21:36 #2 by babynus
Strange to get such issue in V3.4.0 as there was no dev around this code and functions.
I will investigate.
Ticekt #1146 recorded
23 Jul 2013 15:00 #3 by babynus
Case to product is specific :
- Resource enter some real work on ticket
- Ticket must be linked to planning activity
- Resource who enters the real work is not assigned to the planning activity of the ticket.
Issue is fixed.
Will be deployed in V3.4.1
In /model/ImputationLine.php; replace lines 152, 153 with :
if (isset($obj->WorkElement)) {
				  $ass->realWork=$obj->WorkElement->realWork;
				  $ass->leftWork=$obj->WorkElement->leftWork;
23 Jul 2013 15:36 - 23 Jul 2013 15:38 #4 by Rexeh
Also confirmed that this has resolved the issue.
Would this be related to the attached image?
It appears that a small portion of the work table are getting idProject 0 associated to the entries... I have been unsuccessful in tracking down the origin yet. This then results as you will know in the reports showing resources/time/money against "0"
Last edit: 23 Jul 2013 15:38 by Rexeh.
23 Jul 2013 21:41 - 23 Jul 2013 21:41 #5 by babynus
No, it's not directly, even if the same lines may be concerned.
I recorded Ticket #1148 to solve this issue that will not show direct errors but could lead to errors in reports.
Last edit: 23 Jul 2013 21:41 by babynus.
