ProjeQtOr free project management software - All projects- Ticket view not working in 3.4.0 for some users intermittantly - Page 2 - ProjeQtOr
23 Jul 2013 15:19 #7 by Rexeh
Do you mean line 62?
<th field="actualDueDateTime" width="7%" formatter="dateTimeFormatter">${actualDueDateTime}</th>
This is the line number my end. I can confirm removing this fixes it for the clients involved.
23 Jul 2013 15:28 #8 by babynus
Yes, that's right, line 62.
Happy it fixes the issue. So I can now find a definitive fixing.
It is a dojo regression in V1.9.0.
I'll try V1.9.1, maybe it fixes this issue.
I'll also look for a workaround.
The following user(s) said Thank You: Rexeh
23 Jul 2013 15:31 #9 by Rexeh
Brilliant, thanks for the help!
23 Jul 2013 22:39 #10 by babynus
Unfortunately, I cannot reproduce issue to fix it definitively.
Could you give some precisions:
- the locale (language) used by users facing the issue
- the defaut date format in the locale (MM-DD-YYYY for instance)
- one exemple of the "inital due date" and "actual due date" for the first ticket in the list appering with ...
24 Jul 2013 08:51 #11 by climb4fun
Hi all,
what helped in our team, was to change language to English UK. It's a workaround, not a solution, but it helps.
Klaus
24 Jul 2013 09:45 - 24 Jul 2013 10:06 #12 by Rexeh
climb4fun wrote: Hi all,
Klaus
Am I missing something here? There is only
English
French
German
Spanish
Portuguese
Russian
Chinese
In our list... there is no ENGLISH US and ENGLISH UK variants?
If you mean the OS Locale then all set to English (United Kingdom)
SD: dd/MM/yyyy
LD: dd MMMM yyyy
ST: HH:mm
LT: HH:mm:ss
Last edit: 24 Jul 2013 10:06 by Rexeh.
Time to create page: 0.072 seconds
