ProjeQtOr free project management software - Project View in Today not actual - ProjeQtOr
19 Jun 2013 23:59 #1 by aimsoft
after adding about 60 Projects, all worked fine. Then i begann to change the which Project depends on which. Then i saw not all projects was listed and my changes are not viewable in the today view. In the projects list all was correct but the today view does not change the view, sometimes it works after some logout/logins but something didn't change in the view.
Also that only 70 projects are listed, i change the global setting from 100 to 200 but some projects not listed, and the projects (all of them) have all the same config.
It seems that it have to problems
.) view refresh every 10th logoff
.) too much projects will not listed in view
It's just a bug in the view.
20 Jun 2013 11:49 #2 by babynus
I never met this issue.
Did you check that current user is affected to projects ?
In today screen, only affected projects (and their sub-prjects) are listed.
20 Jun 2013 11:51 #3 by aimsoft
Yes i'm working with the admin that is project leader to see all projects.
20 Jun 2013 13:29 #4 by babynus
But even as admin, in today screen user only sees projects he is affected to !
20 Jun 2013 14:01 #5 by aimsoft
In this case he is owner of the projects, that should be enough or not?
20 Jun 2013 14:19 #6 by babynus
No.
Criteria is : affected to the project.
