ProjeQtOr free project management software - Test Session Issues (ver. 3.2.2) - ProjeQtOr
29 May 2013 11:38 #1 by savio
Hi Babynus,
at first i want to congratulate you, for your software. It is the best software I have seen for the functionalities offered. We are evaluating it's use in our organization.
Below you can find some issues detected using the Test Session functionalities:
When we try to run a test case from the “test case runs” section of a Test Session, selecting one of the shown icons (edit, pass, fail or block), we have some issues:
1. sometimes appears this message “Some field contains invalid data. Please correct first”.
2. sometimes the Pop-up (named Test case run) doesn’t appear and the status directly changes in blocked or passed without asking for a comment.
3. sometimes the test case name is automatically replaced with another existing test name. We can check this error reading the “Change history” section where there are two different test case names for “value before” and “value after”.
Moreover some questions about test case runs.
1. In the section “Change history”, the id displayed for the test case added is different from the original. Is it correct? If so it can give rise to confusion.
2. The Manual of Project’or RIA about Test sessions explains that test cases are “linked” to test session. This term is ambigous because could lead to use the "Linked Element" section. Is better to use the term "added" instead of "linked" ?
Thanks in advance
29 May 2013 14:30 #2 by babynus
It means some data is not correct. Incorrect fields are highlighted. For instance, when status is set to failed, a ticket must be selected (or created).
It is normal for status : OK and Blocked. By default only Error status requires a description.
But it is amways possible to add a comment afterwards, using the edit button.
I never faced this issue. Could you descibe use case to reproduce this issue ?
id displayed is the id of the link, not the id of the test case.
Ticket #1094 recorded
You're right.
