ProjeQtOr free project management software - Apache not Starting after updating to Easyphp13.1vC9 - ProjeQtOr
14 May 2013 07:03 - 14 May 2013 07:11 #1 by kay
I was able to successfully update Easyphp 12.1 modules and seeing them just fine when I deploy
that program....so yes, I'm able to continue with my project in that program.
When I back of that program and start the Easyphp 13.1 program....Mysql is green however Apache is
red(Stopped).
Questions:
1) What do I need to do to use the 13.1 update?
2) Will I still be able to pull up my current projects in EasyPhp13.1? If
so can I just copy the portable file from Easyphp12.1 and put it under
EasyPHP13.1?
3)I have a webhost using a SSL, can I add projectoria and if so what is the
procedures?
Thanks in advance
Last edit: 14 May 2013 07:11 by kay.
14 May 2013 15:51 #2 by babynus
First of all, your issues are not linked to Project'Or RIA, but to EasyPHP, so maybe you'll find more helpful information on EasyPHP forums. :evil:
But, as I am a very kind fellow, I'll try and give a little help B) .
The more likely is a conflict with port 80.
To be sure, check Apache log file : you'll have error reported here.
Possibly, previous Apache session was not completely stopped.
Look in running processes and services which one could use port 80.
Yes.
If so can I just copy the portable file from Easyphp12.1 and put it under
EasyPHP13.1?
Yes for the files. For MySql db, perhaps an Export / Import is more prudent.
procedures?
Yes.
you have nothing to do in Project'Or RIA, just reach it through https
The following user(s) said Thank You: kay
19 May 2013 06:00 #3 by kay
Thanks for helping with Questions 1 & 2.....it's working :woohoo: :woohoo: :woohoo:
As far as question #3..let me see if I'm explaining this correctly.
I want to be able to collaborate with my team online(securely)...can I do this now using Easyphp 13.1vc9?
OR
Do i have to wait for the new Web version EasyPHP 13.1 WEb Hosting.
*I currently have a webhost SSL what's the appeal to use easyphp 13.1 Webhosting?
(sorry if I sound confused that's because I am.....not that tech savvy :blink: :blink: :blush: )
19 May 2013 11:51 #4 by babynus
SSL mode depends on Apache, and can be activated on EasyPHP for long.
Generic docs, mostly available for linux:
doc.ubuntu-fr.org/tutoriel/securiser_apache2_avec_ssl
httpd.apache.org/docs/2.4/fr/ssl/
Some specific EasyPHP how-to:
www.developpez.net/forums/d894806/webmas...r-ssl-easyphp-5-3-a/
20 May 2013 02:30 - 20 May 2013 02:42 #5 by kay
Still having trouble....I didn't want to bother you so I've been racking my brain over this....I'm getting "invalid Login Parameters"
I've checked everything that I can think of...I even did a stared and compared
1) I have 12.1 on another computer which i can get into just fine and see projects
2) I have 13.1 on another computer (which I was able to bring my 12.1 files over tothe 13.1 upgrade. I'm getting to login screen and Tried admin/password (which is the same as 12.1 version but getting the failure.
2a)I tried admin/admin.till having trouble. I tried removing /tools/parameter.php...but when I do that doesn't allow the Login Screen to even stay So I put it back atleast that will allow me to get to the login screen.
Question??? Am I having a directory or path issue? (I only asked because I'm not seeing parent directory icon link blacked out like the 12.1 version.
2b)I've reviewed my phpadmin (stare and compare) --again not tech savy so I backed right the hell out of it after trying to updated passwords and tried login into the 13.1 version and still received the same message.
**Also, my Security issue-I need to move my tools/paramaterlocation file as warned per manual and forums....but it's not working correctly.
HOnestly, I have no clue what I'm doing but I do have a suggestion
:whistle: :whistle: :whistle: Maybe a video tutorial or video powerpoint presentation that take you step by step could help those like myself who love the program and what to MAXIMIZE the tools as you developed to do. (Hopefully you like that idea, I think it would be well received)
Last edit: 20 May 2013 02:42 by kay.
20 May 2013 15:35 - 20 May 2013 15:37 #6 by babynus
Did you simply try brand new install on your 13.1 ?
admin/password
default is admin/admin
If you want to restart a setup, you have to remove /tool/parametersLocation.php file.
Well : tool is free, basic set-up is simple, basic support is free.
For more complex issues, have a look at "services" (but it's no more free) ;)
Last edit: 20 May 2013 15:37 by babynus.
