ProjeQtOr free project management software - bug with screen Real Work Allocation same as ticket 971 - ProjeQtOr
26 Mar 2013 01:04 #1 by laudoin
I have just installed the last version 3.2.2 and I have the same problem explain in the ticket 971.
Its very difficult to works with this problem.
Thanks you
26 Mar 2013 08:24 #2 by babynus
Is it exactly the same issue, for Admin profile ?
Other profiles may not see top projects if they are not affected to : it is a security schedule.
26 Mar 2013 09:33 #3 by laudoin
All profiles are this issue.
But this issue is not on all projects.
What project parameters can impact this screen ?
Best regards
26 Mar 2013 11:45 #4 by babynus
What impact this screen is Project Affectation :
- users who don't have visibility to "all projects" will only see projects they are affected to.
For instance, if you have projects hiérarchy :
=> P1
=> => P1.1
=> => P1.2
=> P2
If resource such as team member is affected to project P1.1, he will not see P1, nor P1.2, nor P2 : it is a security constraint.
01 Apr 2013 10:07 #5 by laudoin
I try to explain the problem in the attach file.
I check the affection on the project and the problem is not here.
Best regards
01 Apr 2013 18:59 #6 by babynus
Which version of Project'OR RIA are you running ?
