ProjeQtOr free project management software - Real work allocation problem in 3.2 - ProjeQtOr
14 Mar 2013 17:57 #1 by ekolossov
2013-03-14 16:54:28 ***** ERROR ***** ERROR *****
2013-03-14 16:54:28 ***** ERROR ***** on file '/var/www/localhost/htdocs/projectorria/model/ImputationLine.php' at line (285)
2013-03-14 16:54:28 ***** ERROR ***** cause = Array to string conversion
14 Mar 2013 20:06 - 14 Mar 2013 20:06 #2 by babynus
Issue fixed.
Stange it generates an error for you.
For me it does not and generates an "Array" text for the array instead of generating an error.
What is your PHP version ?
Fix is easy, just comment line 285 in /model/ImputationLine.php (a call to scriptLog) :
private static function getParent($elt, $result, $direct=true){
//scriptLog("      => ImputationLine->getParent($elt->refType#$elt->refId, $result, $direct)");
Last edit: 14 Mar 2013 20:06 by babynus.
14 Mar 2013 20:11 #3 by babynus
Found the reason.
It is a PHP 5.4 backyard incompatibility
Converting an array to a string will now generate an E_NOTICE level error, but the result of the cast will still be the string "Array".
You are using PHP 5.4, aren't you ?
15 Mar 2013 10:20 #4 by ekolossov
Yes, we are using 5.4
