ProjeQtOr free project management software - Ver 3.2.0 Menu click/choose/highlight problem - ProjeQtOr
12 Mar 2013 03:34 #1 by JFOC
I found something strange in 3.2.0 on MacOS Safari 6.0.2
At left menu -> Parameters ->expand menu-> user parameters
I am trying to click user parameters but the mouse is only work for click on top of User Parameters Text/icon ( will not work at middle/bottom )
You can see the details in attached
Web Hosting and Server Provider
Web Site: www.jfoc.net
12 Mar 2013 10:01 #2 by babynus
Very strange indeed.
Are you sure it is new in V3.2 ?
This version only added one new menu item...
Can you try to remove access rights to audit screen (uncheck option in "acces to forms" screen), reconnect and check again : does it behave the same ?
NB : unfortunately I have no platform to reproduce this bezhavior.
