ProjeQtOr free project management software - planning in v.3.1.4 - ProjeQtOr
planning in v.3.1.4
11 Feb 2013 16:54 #1 by ekolossov
Got new problem in planning with v.3.1.4 - not started tasks on recalculate moved into 2014 (see enclosed image)
11 Feb 2013 23:23 #2 by babynus
Replied by babynus on topic Re: planning in v.3.1.4
V3.1.4 fixes one bug in previous version : when not defining project for planning, all accessible projects are planned.
Before fixing, projects should be planned one by one only.
So tasks on some projets would not move, because availability would not be shared between projects..
This may explain why this tacks moved.
But could you give more information ?
Is the planned date correct depending on priorities, dependencies, availability of resources ... on all projects ?
12 Feb 2013 08:23 #3 by ekolossov
Replied by ekolossov on topic Re: planning in v.3.1.4
To do this kind of analysis on all 67 projects will take a while...I believe that people involved in this project not involved into any other projects, so this should not affect this tasks. Moreover the previous group of tasks (Iteration1 ) which already started have not moved. And if the date in planned will be not 2014 but 2013 it all will be Ok
12 Feb 2013 08:33 #4 by ekolossov
I have discovered some information - look at the enclosed screenshot for resource planning and you can see that for some reason some tasks are extremely long on this graph...
12 Feb 2013 12:43 #5 by babynus
Could you provide print for dates of the 3 "long" tasks.
The split of this tsks is strange.
For resource planning, you can have 2 parts in bars : grey part reflects the "real work" period. The green (or red if late) part reflect the "planed" period.
This split aims to point out tasks that are split, from real work already done to planned start.
What is stange for these tasks, is that real work bar ends must later than planned work...
It seems there is some real work in 2014...
Could you check this ?
12 Feb 2013 13:13 #6 by ekolossov
Thank you very much - found task where real work been booked to 2014!!!
Now everything is OK!
Time to create page: 0.074 seconds
