ProjeQtOr free project management software - PDF export of reports/work/work synthesis per activity - ProjeQtOr
08 Feb 2013 11:14 #1 by JCDe
It seems that when there are lots of data to export, this PDF export does not work correctly concerning "work synthesis per activity".
Only a ".php" file empty is created.
Thanks in advance for your help.
08 Feb 2013 20:14 #2 by babynus
if file is empty, then you may have an error in the log file.
Please post it here.
09 Feb 2013 16:13 - 09 Feb 2013 16:17 #3 by JCDe
My error log
2013-02-08 10:45:44 ***** ERROR ***** on file 'C:\c:\wamp\projectorria\external\html2pdf\html2pdf.class.php' at line (1251)
2013-02-08 10:45:44 ***** ERROR ***** cause = ERROR n°1 : The tag <BUTTON> does not yet exist.If you want to add it, you must create the methods o_BUTTON (for opening) and c_BUTTON (for closure) by following the model of existing tags.If you create these methods, do not hesitate to send me an email to This email address is being protected from spambots. You need JavaScript enabled to view it. to included them in the next version of HTML2PDF.
2013-02-08 10:45:44 ***** ERROR ***** => #0 C:\c:\wamp\projectorria\external\html2pdf\html2pdf.class.php (1226) -> _executeAction()
2013-02-08 10:45:44 ***** ERROR ***** => #1 C:\c:\wamp\projectorria\external\html2pdf\html2pdf.class.php (5446) -> _makeHTMLcode()
2013-02-08 10:45:44 ***** ERROR ***** => #2 C:\c:\wamp\projectorria\external\html2pdf\html2pdf.class.php (1255) -> _tag_open_TD()
2013-02-08 10:45:44 ***** ERROR ***** => #3 C:\c:\wamp\projectorria\external\html2pdf\html2pdf.class.php (1212) -> _executeAction()
2013-02-08 10:45:44 ***** ERROR ***** => #4 C:\c:\wamp\projectorria\external\html2pdf\html2pdf.class.php (5446) -> _makeHTMLcode()
2013-02-08 10:45:44 ***** ERROR ***** => #5 C:\c:\wamp\projectorria\external\html2pdf\html2pdf.class.php (1255) -> _tag_open_TD()
2013-02-08 10:45:44 ***** ERROR ***** => #6 C:\c:\wamp\projectorria\external\html2pdf\html2pdf.class.php (1212) -> _executeAction()
2013-02-08 10:45:44 ***** ERROR ***** => #7 C:\c:\wamp\projectorria\external\html2pdf\html2pdf.class.php (408) -> _makeHTMLcode()
2013-02-08 10:45:44 ***** ERROR ***** => #8 C:\c:\wamp\projectorria\view\print.php (136) -> writeHTML()
2013-02-08 10:45:44 ***** ERROR ***** => #9 C:\c:\wamp\projectorria\view\print.php (120) -> finalizePrint()
Last edit: 09 Feb 2013 16:17 by JCDe.
09 Feb 2013 16:53 #4 by babynus
OK
Issue is strange, and don't seem linked to number of lined to display.
I recorded issue as ticket #998.
Can you please check is one on your activities contain something that could look like a HTML tag.
There is an error about a <BUTTON> tag...
