ProjeQtOr free project management software - Closed Project - ProjeQtOr
Closed Project
31 Jan 2013 15:26 #1 by ekolossov
Closed Project was created by ekolossov
Issue came up during an audit. If project completed and closed then we cannot show anything except the project itself (no planning, no activities, etc.).
Please add ability to select closed project in the left top corner list the same way as it possible for other items (it can be check box as well near this drop-down list). I hope this will do the trick to set the project to closed one and see the all items related to it. Please ASAP!!!
Evgueni
31 Jan 2013 20:21 #2 by babynus
Replied by babynus on topic Re: Closed Project
Is it Mushy's law :evil:
Registered as Ticket #982
Not only : it is mostly likely that items for closed project are also closed...
So you must check "show closed items" in the list to display items.
Please ASAP!!!
Not easy, as of today this list is static (never reloaded) and depending on static lists, calculated only on startup.
As a workaround, you may temporarily re-open closed projects you want to see.
01 Feb 2013 08:44 #3 by ekolossov
Replied by ekolossov on topic Re: Closed Project
Reopen will lead to more procedures and problems...
