ProjeQtOr free project management software - Adding an resource/contact (affectation) to a Project - ProjeQtOr
17 Jan 2013 10:22 #1 by IC_PRQA
A resource has to exist at the top level of a project.
For a project at a lower level it would be easier to only allow selection of the resource from a list that has been entered into the top level.
Currently it is confusing as the resource cannot see their activities etc until that has been completed.
17 Jan 2013 23:06 #2 by babynus
No, it is not mandatory.
No, because a reousouce can be affected to a sub-project without having visibility to the top one.
Resources can only see activities of the projects they are assigned to, and their sub-projects : it is the basis of the security restriction in Project'Or RIA.
Example :
Project 1
=> Project 2
=> Project 3
=> => Project 4
Project 5
Resource A affected to Project 1 sees all data of projets 1, 2, 3 and 4 but none of Project 5
Resource B affected to Project 3 sees all data of projets 3 and 4. that's all. Resource B is not even aware that project 3 is a sub-project of project 1.
28 Jan 2013 18:36 #3 by IC_PRQA
This is my example
Project 1
=> Project 2
Project 2 is a sub project of Project 1.
Unless I put the Resource A into Project 1 then the Resource A cannot see their activities in Project 2.
Please make the selection of resources only available if they are in the project above and not all resources in the entire system.
In Project 2 I selected Resource B from the entire set of resources but did not add Resource B to Project 1. Resource B could not access their activities. Try it, it is frustrating until you know what you have to do.
28 Jan 2013 21:41 #4 by babynus
Or you can affect resource A to project 2.
This a basis security constraint.
Resources cannot see activities of project they are not affected to.
No, this is not possible.
It mist be possible to affect Resource A to project 2 without needing to affect it to Project 1.
This also is basis security constraint.
Exemple :
Project 1 = Bad Projects
Project 1.1
Project 2 = Good Projects
Project 2.1
If I affect resources to Project 1.1 or 2.1, I just don't want them to know in wich Top project the project they work on is.
I'm sure they can. Try disconnect / reconnect to retrieve correct access rights.
06 Feb 2013 11:23 #5 by IC_PRQA
I do disconnect and reconnect.
What I need is to only be allowed to select resources from the project in the level above as this is the control that allows the resource to see a task allocated to them. It should be simple to just put that selection process in and not select from all resources in the entire system.
07 Feb 2013 22:23 #6 by babynus
It is not possible : it must be possible to affect resources that are not affected to top project.
It is a basis in Project'Or RIA.
Many users use this functionality to manage access rights (I do !), so I can't won't change it !
