ProjeQtOr free project management software - Selecting column - ProjeQtOr
Selecting column
10 Jan 2013 13:27 #1 by jmmbb
Selecting column was created by jmmbb
Hi !
Happy new year for all !
Is it possible to get hability to select displyed columns in lists (projects, activities, milestones, tickets) like in Planning ?
is it possible to get hability to resize columns ?
It will be great for adjusting screen to users's wishes. Sometimes, some columns are too small to be usefull (for exemple, i use a project code like 2013_XXX where XXX is the number of project for year 2013. In project list, on a 1280 x 1024 screen, you can only see 2013_XX, then project code column is unusable :( but closed column is visible, i i don't mind this information !).
Nice year !
10 Jan 2013 14:32 #2 by babynus
Replied by babynus on topic Re: Selecting column
Possible, although not easy.
Request registered as Ticket #953.
NB : this could be an global configuration (done by admin) or a personal configuration for each user (like on planning)...
NB : if you need it quickly and globally, you can force hiding a column by deleting it in the $_layout definition in the php class for the object.
Possibly not : it should be available by default on the Grid control, but is not effective, not knowing why...
