ProjeQtOr free project management software - Resource planning - ProjeQtOr
Resource planning
08 Jan 2013 09:30 #1 by ekolossov
Resource planning was created by ekolossov
when attempt to export into PDF format the following error occurred:
Fatal error: Allowed memory size of 536870912 bytes exhausted (tried to allocate 82 bytes) in /var/www/localhost/htdocs/projectorria/external/html2pdf/_class/parsingHtml.class.php on line 435
Clear cache will not help (browser - Firefox 17.0.1)
08 Jan 2013 15:21 #2 by babynus
Replied by babynus on topic Re: Resource planning
This issue is not local on client, it is on server side : PDF generation requires lot of memory (RAM).
But memory used by each thread must be limited to avoid to overload server with one only process.
By default, max memory allowed to generate a PDF file is 512 MB. You can change this in Global Parameters : "memory limit for PDF generation".
Other solution is just to print the report to a PDF generation printer (for instance using PDF Creator...)
08 Jan 2013 16:53 #3 by ekolossov
Replied by ekolossov on topic Re: Resource planning
Yes, max memory change works. Hopefully filters can help as well
08 Jan 2013 21:12 #4 by climb4fun
Replied by climb4fun on topic Re: Resource planning
That's the way we do it. Works fine.
Klaus
09 Jan 2013 08:28 #5 by ekolossov
Yes, I know but still we want to see not the all users but selected set
