ProjeQtOr free project management software - Upgrade from 2.6.3 to 3.0.1 activities "undefined" in planning - ProjeQtOr
29 Nov 2012 21:39 #1 by jphuart
The process was easy, but in the planning screen all my activities are replaced by the mention "undefined".
Any idea about it?
I reverted to the previous version. If you want the backup of my database in v2.6.3 to test the upgrade, let me know.
Ciao
Jean Pierre
29 Nov 2012 22:07 #2 by babynus
If your data is not confidential, you can send it to This email address is being protected from spambots. You need JavaScript enabled to view it..
I'll have a look.
29 Nov 2012 22:19 #3 by jphuart
Delivery to the following recipient failed permanently:
Technical details of permanent failure:
Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about the cause of this error. The error that the other server returned was: 530 530 SMTP authentication is required. (state 13).
29 Nov 2012 22:24 #4 by babynus
Sorry : it is This email address is being protected from spambots. You need JavaScript enabled to view it.
:silly:
29 Nov 2012 23:46 #5 by jphuart
Well, following the suggestion that creating a new activity will solve the problem, I dropped my database, restore the dump of previous version, deleted the parameterlocation.php and ... everything went fine.
It just works (except the small problem of '&nbsp' solved through the good suggestions given in the related post.
So, I don't know what has happened, you can throw away my dump, sorry for the time lost reading this topic.
Thanks for the support.
Ciao
Jean Pierre
30 Nov 2012 09:26 #6 by F.Cheminade
Hello I have the same probleme but it's correct if I use Firefox navigator.
Can you try this ?
